New Upper R6/R1
- Fizzinatorr
- Level 6.5
New Upper R6/R1
I'm thinking of updating my FZR 1k my windshield is cracked, my upper fairing is broken and my headlights don't work so it seems to be the same cost
Few Questions:
What will fit the bike better? R1 or R6
What year should i go with?
Will wiring it be impossible or just difficult?
Freeze i def. wanna hear your input on this one.
Few Questions:
Re: New Upper R6/R1
The 1k FZR was a pysically large bike as far as I remember. Because of that, I would go with the 99-02 R1 upper. It propably will fit with the least amount of trouble. You will have to modify or custom make a birdcage I would think. The wiring is not impossible. If it is just the headlight wires I could help out with it. I can swap the wire connectors to work with the single fillimant bulbs and keep it looking factory if you want some help with it.
Good luck and let us know how it comes along.
Rob
Rob
- billy_awesome
Re: New Upper R6/R1
Unless you get R1/R6 side fairings, The upper and side fairings won't align. Unless your a terrific plastic welder and bondo king, your going to get yourself in trouble.
These bikes can have R1/R6 upper and side fairings, the brackets arent that hard to design either.
Good luck.
Good luck.
Re: New Upper R6/R1
This bike has stock lower fairings, but I'm unsure of what the upper is - can someone clarify?
Re: New Upper R6/R1
Man thats sharp looking!!! Is that a cbr upper?
1992 FZR 600
Yoshi exhaust
K&N pods
Airtech R1-kit
02 R6 fork swap
02 R6 Swingarm
520 chain conversion
07 R6 controls
Vortex R6 clipons
07 R6 radial master
2003 CBR 600rr
bone stock
Re: New Upper R6/R1
i'm jealous of his fender and hugger
- Fizzinatorr
- Level 6.5
Re: New Upper R6/R1
thinking 2002-2003 R1 currently
Thoughts?
Thoughts?
- Fizzinatorr
- Level 6.5
Re: New Upper R6/R1
Re: New Upper R6/R1
The R1 front fairings are supurb looking. That would look great on a FZR 600/1000.
- Fizzinatorr
- Level 6.5
Re: New Upper R6/R1
Scored a set of fairings on e-bay
so now it's going to include the tail fairings as well
going to be 2002-2003 R1
Stuff I need: Headlight,seats, windscreen
Need to figure out: Where to remount exup servo
Headlight wiring
Tail light wiring
brackets to mount
All help is appreciated.
Headlight wiring
Tail light wiring
brackets to mount
- abs929cbrrr
- 1000+ Posts
Re: New Upper R6/R1
thatuppers a 02-03 R1. i was going to do a full fairing swap with that yeat but unless you got money they R1 uppers will run you $150 for somthing needing work, fairing stays will run a good $100 and a head light assy will run at least $150 for a used one. those year R1 parts are very expensive.
02 xr200r set up for XC
96 trx300ex set up for XC
im roadbike less!!!!!!
- Fizzinatorr
- Level 6.5
Re: New Upper R6/R1
yep, i got lucky and bought an entire new fairing set, every piece
making my own fairing stay
but now i'm starting to plan my wiring...and oh man this looks complicated:
Re: New Upper R6/R1
It shouldn't be that hard. All you should have to do is splice the light bulb connectors from the R1 into the wiring for the FZR. You should also have to add a little bit of wire if the headlight uses seperate bulbs for low and high beam.
- Fizzinatorr
- Level 6.5
Re: New Upper R6/R1
I've never wired different headlights...i can do a bit with wiring though
unfortunately i'm having a hard time finding the 2002-2003 headlight for under 190.00 and the wiring harness seems to be around 50.00 is there a way to create my own wiring for the headlights since i'll have to be slicing anyways, basically what i'm asking is getting the R1 wiring harness 100% necessary?
