So this means, now i can continue the swingarm swap....Which i have to go buy the bearing for still. Tomorrow I'm buying the matte black for the frame and swing.
Thanks to shredex for stoppin in to help
shredex wrote:didnt smoke out of the exhaust.....everything else was just about smoking...I hope you put something over the crank case exhaust so no more rain goes into there.
and it did sound good...sounded just like mine when I had that exhaust...just need a good sync.
when are you guys gonna do the sync? Id like to try syncing with that tool he has.
oh wait...you cant sync till you get that new cover...or use the old one because the bike has to be running when syncing
what do you mean a motor??? All i need is the cover, i already have the coil and a good pickup, we know that.shredex wrote:yea...TK has a cover for $50 shipped w/powder...and the cover set is $150
go onto the yzf forums and try selling your yzf cover and use that money to get a normal fzr motor...
there is someone around me selling a fzr motor for $100...I tried getting ahold of him, but didnt get a reply
I've heard it could possibly be a stuck float in your carbs...Black smoke is fuel, not oil.shredex wrote:hey,at least its not laying around at your place!
wonder if the black smoke my exhaust produces is because of a bad piston ring...it would explain my power loss...maybe its not the coils after all O.O
i would cry if that were the case
so you already took apart your carbs and know for a fact that its not a stuck float? Cuz yea, the smoke is b/c your running rich, but you might be running rich b/c your carbs. My friend that knows alot about carbs says its your float or a f*ck up JET. So i would rip them apart...shredex wrote:not a stuck float...the smoke means that im running rich...i cant seem to make the richness go away though...
you still need to get carb cleaner and soak you carbs...theres this stuff you can set it in over night called "Zep" that will clean them complety...dont know how much a gallon of that stuff costs though...TK would know...he bought a 5 gallontub of it.
have you got a lead on a new cover yet?
hahashredex wrote:yea...iv torn them apart about 5 times in the past month to find the bug...i adjusted my floats also...and checked everything to see that they were in working order.
you need to also swap back those float bowls...
