LOL295FZR600 wrote:abs600fzrr wrote:190 is way to big for a 5.5" rim. run a 180 like it ment, it wont turn with a shit with a 180 anyway haha so no reason to go even larger.
Im going with a 180, Im bigger and stronger than you so I know I wont have a problem turning it.
HOW TO: 99-02 R6 Swing Arm Mod **Added to WIKI**
Re: Almost done with R6 Swingarm Mod**NEW PICS**
'03 Liquid Silver R6
'91 FZR 600
YZF swingarm conversion
Bridgestone BT-016s 110/170
Many hours on this project but finally finished. I added a lot of pics to show you all. Funds ran me low. I still owe Rage some money for a part and cant afford to get a tire and chain right now. Looks like it will be on hold for some time middle of next week, I hope. I have a buddy of mine finding me a good used take off at his shop. If I can get that maybe borrow some money from my son.
I also noticed that I will need a new mid pipe for my short can. Will take it down next week when I get paid to have one fabbed up from a friend of mine at the local muffler shop.
Im pretty pleased how it turned out. Really not a lot of fab work just a lot of grinding and cutting to get the swing arm and shock mounted.
Oh, ABS..........I dont need to machine down the cush drive. It all lines up perfect!
Shock mount complete
Rear MC. Had to re-use Fzr and space it out for springs and such to work right.
Pivot Bolt Axle nut in place and tight. Remember, I used the R6 one.
Look how perfect the shock lines up in the center of the swinger
I didnt have to space the left rear sets at all. Its close but does not touch at all.
Shock mount bracket welded. I will weld the angle to the sub frame at a later time. For now I have it bolted.
Jt front 520 sprocket mounted and blue loctite. I even took MSZILVES idea and went with it on the screw.
Complete set up minus the wheel and chain.
Different angle. Complete set up.
From the rear.
From the side.
From the rear.
From the side.
Re: Finished with R6 Swingarm Mod**NEW PICS**
hey, what would you charge to make that same shock mount for me? i was going to look for a guy to make one for me here, but that tis exactly what i need, so i wont need to draw it up. i am using the same shock, just a little different angle, mine mounts to the subframe in the same place. if you can make that without the mounting holes, that would be perfect!
I did that.
Ill do it this weekend for you. I made a template for this purpose. I have the metal already but wont be able to have it welded until early next week. Is that ok?
- megaloxana
Turned out really well mark, nice job. Do you have to relocate your battery?
- abs929cbrrr
- 1000+ Posts
that swingarm bolt is gonna hit your ankle. why didnt you use the stock fzr one and get pivot sleeves made?
megaloxana wrote:Turned out really well mark, nice job. Do you have to relocate your battery?
No, I mounted the shock bracket on the bottom of the subframe instead of the top like crazy ivan did. Worked out better.
ABS, I spaced out my right side rear sets so it doesnt rub my ankle. I dont like the look of the axel nut but oh well. I didnt do the spacers because of the amount of funds I had for the project. Everything worked out for me except I need a damn tire and chain.
Nice. How long of a chain do you need?
that would be awesome! let me know what it would cost and shipped to 03082. i have my setup on there now, but it is just bolted together, will work, but i really wanted it to be a little more better! like yours!95FZR600 wrote:Ill do it this weekend for you. I made a template for this purpose. I have the metal already but wont be able to have it welded until early next week. Is that ok?
I did that.
looks good mark, any plans to countersink that nut?
My FZR6 Rebuild
My FZR6 Rebuild
Cad, I dont know if you were going to give me a chain or what but thank you for asking. He bought me a 520 and I only cut off two links.
target, I should have it done by Tuesday. And sent out by wednesday.
Genesis, For right now Im going to leave it then dremmel out the inside bushing area so I can get a socket in there. I just want to ride it!
I was so fortunate today. My buddy (derek) who drove over to my house every day at 5pm and stayed til 11pm every night this week to help me with the mod of the swingarm drove around this morning and bought me a 520 o-ring parts unlimited chain and then went to our other buddies shop(freedom power sports) and picked up 4 used take offs and we picked the best one then went 25 miles to have it put on the rim for $12 bucks from a class mates work(cycle gear). I owe him big time now.
As you can see, it lines up perfect!
Again!
Again!
Re: Chain and tire install today;R6 Swingarm Mod**NEW PICS**
nice job ..... that looks so sweet.
post pictures of wheelies A.S.A.P.
HMMMM....damn Mark
, I look at the swing arm in my garage then see your build, You are making it hard to not want to do this. O Fock it.... i'll do it this winter. I don't know what I am going to call my bike.
My FZR6 Rebuild
My FZR6 Rebuild
congrats man ..LOOKS BEAUTIFUL !!!!!
now bolt that sucker all up and go ride it ..
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
$25.99 for the swingarm AND the wheel ??
My GOD man !!!! i think my rear brake pads cost more than that.... what an awesome deal !!!!
(i take that back..... looks like about $2000 worth of labor, excellent work!!)
