1996 YZF Superbike
Re: 1996 YZF Superbike
I have read that to avoid using the 3mm cyl spacer you can use the rods from a Euro spec FZS600 Fazer. I have sourced a set of them.
Will YZF cyl, pistons, head, assembled on top of FZR600 bottom end with FZS rods in the middle give me what I want?
Also, are rods removeable without splitting enhgine cases in an FZR?
Street-2005 GSXR1000 and 3rdWheelTrailer- SupersportTourer
SOAR Novice #22
Race-96 YZF 600 Lost Era Racebike
-99 R6 Rookie Cup Racebike
Unlike golf, football, basketball, and soccer, motorcycling requires TWO balls !
SOAR Novice #22
yep can be done without splitting the cases, you will need to remove the sump pan though. I didn't even take mine out of the frame when i did it. If you use the fzs rods and they have the same bearing center to center as the fzr rods then you should be able to get by without using a spacer plate, from memory your compression will be about 13.1:1.
Sorry about taking so long to answer questions asked of me.
The rear is a 180 mounted on a stock wheel. We were racing it in CCS and changing wheel size was out of the question. With the altered setup the bike has, the rounded tire profile only added to the turn-in quickness. The rear ride height is raised and the frorks are also raised to aid in turn-in. This is a bike that handles very similar to a 2002 Supersport R6 that we were also racing at the same time.
This is not a bike for amatuer riders. It weighs 340 with race tank settings. It runs a total loss ignition and has no starting system other than push it. The brake pads are Carbon Lorraine ceramic/kevlar and it is 2 finger braking. The only thing holding the bikes performance back is the stock carbs and an old careful rider.
I have, today, purchased a set of 33mm FCR carbs from China Racer and that will enhance the performance greatly. I have run those style of carbs on our GSXR 1100 endurance racer and several FZ and FZR 750 and 1000s.I have a dyno and a complete selection of jets. I am anxious to find out how bad I can spank the 2008 R6 that couldn't outrun me down the back straight at Road Atlanta in September.
After my race partner retired from racing we sold the R6 and the YZf sat in my shop gathering dust. Two winters ago I decided that it was time to give the old girl a new look, so I devised the paint scheme after looking at lots of team Yamaha race pics. The paint is exactly like the race scheme used on top line factory GP Yamahas. I did change the scheme a little to better fit the YZF. Last winter I went through the engine and freshened it up with new rings, bearings and fresh valve seats. I have changed the cam timing from when we last raced it to improve corner exits.
RdRcr,
is the engine stock apart from the cam setting?
Are you willing to tell us what that involved ?
Not at all stock engine. Wiseco 13:1 pistons, milled head, Web cams, Stainless valves, ported head with radiused valve seats three angled blended 60 and 15 degree. FZR crank w/Carillo rods, FZR clutch w/ Barnett kevlar and HD springs, FZR igniton, stock coils, stock plugs and D&D pipe. Stock airbox w/Unifilter filter (it's a cleanable foam filter), I picked this filter for two reasons, cost and flow characteristics. On the dyno the Unifilter gave more HP than the K&N filter and it is also cleanable. The cams are also degreed.
RdRcr,RdRcr150 wrote:Not at all stock engine. Wiseco 13:1 pistons, milled head, Web cams, Stainless valves, ported head with radiused valve seats three angled blended 60 and 15 degree. FZR crank w/Carillo rods, FZR clutch w/ Barnett kevlar and HD springs, FZR igniton, stock coils, stock plugs and D&D pipe. Stock airbox w/Unifilter filter (it's a cleanable foam filter), I picked this filter for two reasons, cost and flow characteristics. On the dyno the Unifilter gave more HP than the K&N filter and it is also cleanable. The cams are also degreed.
That is some set of investment you have in that motor, certainly more expensive than the original bike by the sound of it.
Now you can add a set of 33mm FCR carbs from China Racer....bogey time at Road Atlanta.
when you gonna be at road atlanta?
April 28 - May 1 for the HSR Mitty race. If you're there come by and say howdy. We race the Historic MotoGran Prix series. Like how I third personed myself?
I think I will come up too this race. Im only 1 1/2 hours away. Im starting a 660+ build this week.RdRcr150 wrote:April 28 - May 1 for the HSR Mitty race. If you're there come by and say howdy. We race the Historic MotoGran Prix series. Like how I third personed myself?
Yzf600R: Yamaha 50th Anniversary Paint scheme, Moto-777 Fairings, Zero Gravity Double Bubble Windscreen, Yoshi RS3 Racepack slipon exhaust, 2007 R6S Swingarm, 2007 R6S Rear Wheel, R6 yellow Wheel Stripe, 2002 R6 Tail, 2008 R6 Rear shock, RK 520 XSO X-Ring Chain, 14t/48t Vortex Sprockets, Tasty Nuts Fairing Bolt Kit, Scorpio Alarm, Hi/Lo HID from dabears, Carbon Look: Bar ends, Levers, Foot pegs, and Sliders. Motor painted with Motip Flat Black, Frame painted Motip High Gloss.
- Level 4.0
^^^ take lots and lots of pictures we all love to see a great build.
+5 on that, any "GOTCHA's" that you find will give those who follow in your footsteps a heads up.Freestyle72 wrote:^^^ take lots and lots of pictures we all love to see a great build.
Thanks in advance
Be safe and good luck!RdRcr150 wrote:April 28 - May 1 for the HSR Mitty race. If you're there come by and say howdy. We race the Historic MotoGran Prix series. Like how I third personed myself?
Pleasure to read this thread.
Thats a nice bike you have built yourself there,very impressive.
Hope you have a good time this season,and any photo's you post,will certainly be enjoyed on the forum
A new addition dual accel pump, 33mm Keihin CR Flatslides. Initial dyno results are in and HP went from 116 to 119. I am still dialing in the carbs on my dyno, but customer work comes first.
http://www.bikepics.com/pictures/2207004/[imghttp://www.bikepics.com/pictures/2207004/][/img]
