I'm going to steal this post right out from under thatkid's nose!
I drove down to TK's house yesterday, got there around noon and we started workin on the scopper. Our goal was to get a rolling chassis by the end of the day. Sounds simple right? He already had the front end so lets just find the geometry and go at it!
Cleaning the engine
Rolling..... front end?
The Man Tent
Cleaning the engine again
Is that a Big Wheel!?!?
Since TK is making the frame the gas tank as well, we tested out the volume of it. His goal in the back of his mind was to have a gallon at least. Keep in mind his frame was made out of some random piece he picked up at a store.
And DAMN DID HE GET LUCKY!!!! 1 gallon EXACTLY!
Leaks
A gremlin came by to weld the holes up.
New Hotness
Cutting Fun
So we worked pretty much 12 hours and got next to nothing done. WE had the front end ready to get welded up to the back, and then it fell over and wrecked the handlebars (need to be touched up and painted again). Then when making the brackets to connect the frame to the engine, we could not drill through the metal because the drill bits were being shitty. Then we got the drill bit sharpener out which didn't work right either (we sharpened for a half an hour and it didn't make any difference). Then we painted the belt cover for the engine outside, but the temperature changed too fast and the paint cracked so removing all the paint and repainting that for the day was worthless. Then TK wanted to make a part for the frame to make it look a little nice where it connected to the front end and his saw would not bite into his piece of metal he was trying to cut, and then the piece moved and screwed up his cut, so that piece was crap. Essentially at the end of the day we had nothing to show for our work except a clean kick start lever and half of a rolling chassis.
Defeated, we went inside and started moving the tools back to the basement. Then we both got switched into cleaning mode somehow and went ape escape on his basement. It took us maybe 3-3 1/2 hours from the time we started bringing tools down to when we were done. But it looked awesome. I may have black lung from all the dust but dayum it looks nice!
We need some pics of that!!! Old and busted???? NEW HOTNESS!
