my new toy :)
ronny86
Re: my new toy :)
the brake hoses were upgraded to braided ones roughly 1.5 years ago, ill get some DOT3 and replace the fluid just to be safe, least then i can feel that bit safer i guess
Re: my new toy :)
R,
taking aquick peek at the pictures you look to have stainless steel lines NOT rubber. If that is the case Don is spot on & I did say all Fluids for your own peace of mind.
If not that rubber hose set is well past its sell by date so go stainless steel lines.
ronny86
Re: my new toy :)
ye they are stainless steel lines
Re: my new toy :)
OK so replacing the fluid is gonna be easierronny86 wrote:ye they are stainless steel lines
ronny86
Re: my new toy :)
do the fuel pumps on fzrs have a sensor to cut out when petrol is well low? just tried starting my bike then and the fuel pump wasnt doing its usual clicking :-/
Re: my new toy :)
Is this a 1000? If so, then yes - there is a sensor in the tank that will chop the fuel pump at some 'low' level. Once you flip the 'Reserve' switch in the left fairing, the pump comes back on.
ronny86
Re: my new toy :)
nope its a 600, i turn key and theres no clicking at all on reserve or not
having nothing but issues with this bike atm
Re: my new toy :)
*wince* Check your Ignition fuse, check the wires and connectors at the pump, TCI, and main relay assembly (left side rear, behind the seat fairing).
Does the bike start?
ronny86
Re: my new toy :)
found the problem! the earth wire on the fuel pump has frade, think ill buy a new pump
Re: my new toy :)
If it's just a bad wire, can you not simply patch it?
ronny86
Re: my new toy :)
normally yes, but its me were on about here ^_^
ronny86
Re: my new toy :)
i could do it but just need a new o ring crimp
Re: my new toy :)
Ronnie,ronny86 wrote:i could do it but just need a new o ring crimp
sooner or later in biking & bike repair it is a case of "hold yer nuts and go brave "
ronny86
Re: my new toy :)
the beast from the english north east is alive and screaming once again... and no i dont mean my partner >.<
fixed it today and seems better than ever
Re: my new toy :)
Great stuff another satisfied customer if we keep this up we can all retire & go ridingronny86 wrote:the beast from the english north east is alive and screaming once again... and no i dont mean my partner >.<
