yzf engine swap
burnRuber13
yzf engine swap
does anyone know if the yzf 600 engine will fit in the FZR 600 frame because i need somthing with a little more power and my engines got a ton of miles on it
-1994 yamaha FZR600
-shaved frame
-1992 front cowl
-air tech r1 tail
-r6 seat
-1999 yzf 600 tank
-fox rear shock
-vance and hines full exhaust
-stage 3 jet kit
-pod filters
-shaved frame
-1992 front cowl
-air tech r1 tail
-r6 seat
-1999 yzf 600 tank
-fox rear shock
-stage 3 jet kit
-pod filters
dans96fzr600
Re: yzf engine swap
yes it will go in there but you need other parts to get it to work like the wire harness and the like.
1996 Fzr 600
D&D Pipe
K&N Filter
Jetted Carbs
520 Sproket Conversion
Yes it moves well for a 600cc
D&D Pipe
K&N Filter
Jetted Carbs
- abs929cbrrr
- 1000+ Posts
Re: yzf engine swap
to get everything you need most people buy a junk bike. your going to dump around a grand into this mod alone. it only had 10 more hp then them fzr600 so personaly i dont think its worth spend $1000. i was going to do it but i want to check into a gsxr750 motor later down the road....and no that is not a bolt in.
02 xr200r set up for XC
96 trx300ex set up for XC
im roadbike less!!!!!!
Re: yzf engine swap
The 95-96 motor will net you about 10 HP (FZR 72-75hp, YZF 82-85hp), the 97+ YZF motor will net you closer to 15 assuming equal tuning. It is well worth the swap IMO and gets you to pretty much the limits of the FZR chassis. Even with the stock motor, the suspenison gets in the way long before horsepower becomes a problem IMO.
Anyway the 97+ motor is a lot easier to swap, but you will need the motor, electrics, guages, bar switches, ignition, carbs, CDI. Basically anything that plugs into the wiring harness. You will also need YZF headers.
burnRuber13
Re: yzf engine swap
iight i didnt know how much it would cost it seemed like it fit but idk all the stuff you were goin to need
-1994 yamaha FZR600
-shaved frame
-1992 front cowl
-air tech r1 tail
-r6 seat
-1999 yzf 600 tank
-fox rear shock
-stage 3 jet kit
-pod filters
-shaved frame
-1992 front cowl
-air tech r1 tail
-r6 seat
-1999 yzf 600 tank
-fox rear shock
-stage 3 jet kit
-pod filters
Re: yzf engine swap
Well like ABS mentioned, the most common swap is buying a totalled YZF where not much survived other than the engine. I have bought six of them and the most expensive was $1300 (and it was in one piece). If you happen to have the space to store and patience you can even buy YZF's as the come along (or any other kind of bike) and part them for you buy price (or more) and keep the parts you need. That is how I put my current YZF together. I guess the point to the train wreck reply is that the YZF motor is a direct swap (same mounting points) which is at least half the battle when swapping to a different motor.
Re: yzf engine swap
Hey Rich,
Did you use YZF headers? My understanding was that they will present issues with fitment in the FZR fairing.
I've got everything else for the swap, but I thought I was limited to FZR600 exhaust in an FZR400.
