balancing beads ??? no need to take wheel to be balanced !!
mszilves
Level 1.5
Level 1.5
Re: balancing beads ??? no need to take wheel to be balanced !!
Post by mszilves »
Interesting... not much tech info on their site as to how it actually works. Do the beads just roll around inside the tire or do they settle?
'03 Liquid Silver R6
'91 FZR 600
YZF swingarm conversion
Bridgestone BT-016s 110/170
jsph.mitch
100+ Posts
100+ Posts
Post by jsph.mitch »
91 FZR600
Trimmed Tail
YZF VR Upgrade
LED Taillights
Many more mods to come.....
PIMPMYFZR
Post by PIMPMYFZR »
so i went to a local bike shop that deals mostly with goldwings but will service any bike .. they had these beads to balance the bike's wheel .. i grabbed a starter kit which consisted of 2) BAGS OF BEADS one was 2 ounces the other was 1 ounce , 2) special valve stems so the bead dont clog the airway , a bottle and plastic hose to apply them thru the valve stem , the lady mention that she sold them to this guy who kept complaining of shake over 70 in his harley , no matter how many times he had his wheels balanced , she set him up wit these and he supposedly came back and said he got his Hog up to 120 and didnt feel a thing .. hmm but i decided let me get them anyways , so this is what they look like for a sport bike .. just need to get a new front tire now ..lol .. ohh and she recommend that the tire be filled with nitrogen but had said she never had one returned with compressed air ..
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
95FZR600
Post by 95FZR600 »
Check this out. I want to get one.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 03272&rd=1
320210603272
jsph.mitch
100+ Posts
100+ Posts
PIMPMYFZR wrote:so i went to a local bike shop that deals mostly with goldwings but will service any bike .. they had these beads to balance the bike's wheel .. i grabbed a starter kit which consisted of 2) BAGS OF BEADS one was 2 ounces the other was 1 ounce , 2) special valve stems so the bead dont clog the airway , a bottle and plastic hose to apply them thru the valve stem , the lady mention that she sold them to this guy who kept complaining of shake over 70 in his harley , no matter how many times he had his wheels balanced , she set him up wit these and he supposedly came back and said he got his Hog up to 120 and didnt feel a thing .. hmm but i decided let me get them anyways , so this is what they look like for a sport bike .. just need to get a new front tire now ..lol .. ohh and she recommend that the tire be filled with nitrogen but had said she never had one returned with compressed air ..
I used compressed air in my Jeep and my bike with no problems. I had a bad vibe in my jeep, and once I put the beads in the vibe was gone, no matter how fast I was going. I think they are great for the cost.
91 FZR600
Trimmed Tail
YZF VR Upgrade
LED Taillights
the_finch
Level 8.5
Level 8.5
Post by the_finch »
:offtopic:
If you're looking for blue dot calipers, I have a pair I'm not gonna use.
:whistle
(PM me if you're interested.)
1997 FZR600RJ
Luke-a-Tron
Post by Luke-a-Tron »
95FZR600 wrote:Check this out. I want to get one.
320210603272
That thing is pretty sweet looking. I wish it weren't $235.
I'm following this beads thread with quite a bit of interest. Since I put my RaceTech springs on, I get very rhythmic vibration in the bars that is almost straight up and down. I'm thinking my front is out of balance and I'd love a solution as easy as dumping this stuff in the tire.
As far as the nitrogen concerns, the only issue I could see is moisture. You want the beads to be able to move around freely. If they're sticking together they probably aren't going to work as well.
PIMPMYFZR
Post by PIMPMYFZR »
320210603272
The place i got mine from , the lady said they have sold over 2,000 sets of these bead cost me 16 for both front and back . and she says she hasnt had one complaint from a customer about them , now how many of them took her advice and filled the tires with nitrogen i dont know , but im guessing majority of them probably used regular compressed air .my only thing is what time of the day would be the best to fill the air , in the morning when the air is colder or in middle of the day when its hot ..
94' 600RR SOLD**
hid xenon
airtek solo tail
time for a 1000
Luke-a-Tron
It doesn't make a difference really. What matters is the temperature of the tires. You should always check your pressure on cold tires. Cold being whatever the ambient temperature is where you are. As the temperature goes down, the air will shrink and the pressure will drop. I think the ratio is roughly 1 psi per 10 degrees F. Or maybe it's 20 degrees, I forget exactly.
manveru
Level 3.5
Level 3.5
Post by manveru »
on something driven on the street the difference in the air pressure is nothing to worry about. just check pressure with your tires being cold. Luke-a-tron was dead on the ratio is 1 psi. per 10 degrees of change.
well those of us in the UK can get Dyno-beads from scorpion racing just off the north circular road in North London.
They seem to be the only one of 4 dealers in the UK that actually mention them on their web site:-
http://www.scorpionracing.co.uk/
noshoes
100+ Posts
100+ Posts
Post by noshoes »
Back in 93 I turned wrenches at a used bike shop called Motorcycles of Manchester (N.H.) we used this stuff called balance slime. After you mounted the tire u removed the valve core and squeezed a bottle in reinstalled the core and air it up and u were done. I tested all the bikes I used this on (many at 100+ mph) and never had a problem. A few years ago I got a set of Super-swamper T-rex tires for my Jeep and had a high speed shake that I couldnt fix. So I returned to Mom's got 4 bottles of slime and the shake was gone!!!!
This was all I could find on-line.http://www.deltatiresealant.com/products.php :shocker :shocker :shocker
States visited on my 90 FZR 1000
90 1000 w/ 92 USD forks w/ gold valves and Racetech springs,Technomagnesio rims, Ohlins shock,custom dog-bones,Corbin gunfighter seat,Whistler Crusader radar/laser detector,Veil anti-laser coating on plate and head lights,K&N,Yosh carbon slip-on,custom jetting,5 angle valve job & polishing,Ebc pro light contour front disks,R-1 blue dot calipers,Ebc organic pads and steel braided front brake lines,0 grav smoked windshield,carbon bar ends, frame sliders,49 tooth SS ultra light titan-tuff rear sprocket,530 chain kit,Custom ultra light rear disk, Yosh digital temp gauge....It never ends does it???
noshoes wrote:Back in 93 I turned wrenches at a used bike shop called Motorcycles of Manchester (N.H.) we used this stuff called balance slime. After you mounted the tire u removed the valve core and squeezed a bottle in reinstalled the core and air it up and u were done. I tested all the bikes I used this on (many at 100+ mph) and never had a problem. A few years ago I got a set of Super-swamper T-rex tires for my Jeep and had a high speed shake that I couldnt fix. So I returned to Mom's got 4 bottles of slime and the shake was gone!!!!
NS,
I would worry that the tyre coolant effect may be detrimental to my tyres gripping in the corners as per cold tyre syndrome on race bikes by never letting the tyre get to its correct operating temp.
I will stick with the bead idea for the present time .
Dragon
Level 2.5
Level 2.5
Post by Dragon »
Hey guys, just want to let you know the beads does work. I've been using it in my tires for 2 years now, and not a wobble. My ride is always smooth, no matter what speed I'm doing. Just make sure you get the correct amount for your wheels. I'm about to order some more, cause I need to change my tires. Actually I'm about to spray a set of rims I purchased, going from the 3.5 rear, to the 4.0 rear. So, I'm going to need to balance them after I put the tires back on. Thanks, to Dyna Beads we all can do this ourselves. :cheers:
Luke-a-Tron
I so need to order this stuff. I threw the weight off my front tire at some point today and now I get all manner of harmonic vibration as the front and rear wheels come in and out of phase. This could play nicely into the "FZR Orgasms" thread though.
