Ok...one part of the float is smaller and higher then the other.I guess you measure the bigger float height...right?.Thanks
BTW I have the Haynes service manual.I checked the carbs specs as you told me to do but there is no mention about the 14mm float level there.The manual mention only 10.6-11.6mm.A special Yamaha tool is needed or a plastic tube.I guess I should consider to buy another set of carbs.
1991 fzr1000 leaking carbs
Re: 1991 fzr1000 leaking carbs
Don't do that, you'll be throwing away money and should learn how to do this...the fuel level is just a piece of tubing to fit over and when you unscrew the drain plug shows the amount of fuel to a level..
Go on the factory pro website for our bikes instead of us typing out how to do it as they have a good write up with pictures. It'll become obvious at that oint
1992 FZR 1000
Sorry but do you have the link for that site?.Thanks for helping me out.
the link is just
www.factorypro.com
then go to product sales, click yamaha, scroll down to the 89-95 fzr 1000(click) then scroll down and theres a tidbit on setting float height for mikuni 38 BDST carbs..
That should give you an idea..
sorry but the link on my phone shows factorypro.com too and my work computer doesn't allow me too copy and paste as well...
hope it helps
www.factorypro.com
hope it helps
1992 FZR 1000
Got it.Thanks
