I have a couple of these setups.
It is EVERYTHING you need to upgrade your FZR from stock shock to late model R6 shock.....The shock itself(low low miles), a set of my adjustable dogbones to allow you to restore the ride height AND tune it to custom geometry of your choice(higher tail? > not a problem). The upper eyelet on the shock has been bored from 10mm to 12mm so that it accepts the stock upper mount bolt and alloy spacers to center the shock in the upper mount are included. The lower eyelet has been radiused to clear the relay link.
It gets you 'hi' and 'lo' speed compression damping adjustment, rebound damping adjustment, more preload choices, and the late model shocks are rebuildable.
This is a bolt-in and ride it an hour after opening the package kit:
PM me for more details.
