Hello.
I'm getting a G reg EXUP back on the road for a mate of mine.
Issue 1 - When I remove the drain plug, no oil drains!!!???
Issue 2 - Coolant reservior at the back is boiling like a kettle. I flushed the system out, so I know there's no leaks or blockages. New coolant added.
Any suggestions greatly received.
TIM
Drain plug and overheating
I ride;
Kawasaki GT750; Kawasaki GT550
I also own;
Kawasaki GPZ900R (race tuned), Yamaha XJ750, Kawasaki GT550 x2; Suzuki GSX250 x2; Suzuki GP100; Yamaha FZR1000
I also own;
Re: Drain plug and overheating
check the rad cap is sealing correctly as they allow the coolant to boil at a higher temperature with the system being under pressure.If the cap leaks it will boil earlier and you could always do a compression test too.
As for the oil...or lack of it!!!, many use a bit of oil (not all ) The previous owner may not have kept an eye on things and run it dry, which'll do it no good. Check the oil light works in the dash as its a level guage not pressure. It should light up temporarily on cranking
