what does the wire on the left go to? I know the right is the servo
Ik's are not my forte, but the wiring looks original, I would look at the colour scheme of the physical wires and then hunt thro the wiring diagram for those colours
the new fuel pump is installed and works great. but i don't think i am getting any spark. the bike just turns over and over and over but nothing happens
I don't know much about 1k's but that sounds like your pickup coil? Does that 1k have one? I know that they have an actual alternator as opposed to stator? I might not be much help..
Duane... Bike: 1994 Yamaha FZR 1000 EXUP
Factory Pro Stage 1 Jetting | K&N Filter | Corbin Seat | ProTek Keyless Gas Cap | GSXR Mirrors My Thread Cage:
okay....very very weak spark, tried it with a 600 plug
i found this: "PROBLEM FREAKIN SOLVED
Man, after lots and lots of testing, working through the harness etc, I finally figured out why I had no spark.
Drum roll please.
When you read the schematic it show "kick stand relay" or the relay that grounds the ignition box to prevent the bike from starting if it is in gear, clutch, side stand. Well I assumed that when the relay was powered, it would close and tie the ECU to ground. Well, the relay is the opposite. When there is no power, it is continuous and ties the ECU to ground. When voltage is applied, it opens the circuit, then the ECU will provide spark.
Just cut this stupid wire, and now all spark plugs are blazing away with tons of spark.
Well, at least I learned a lot about trouble shooting electronics."
