Exup Grease
Exup Grease
Is there anything anyone prefers to use? I've put now about 5k on my baby since buying it in march and can hear a slight rattle, no biggie but I do want to adjust the servo 3 turns so it's slightly open and I do wanna grease it. Is there a certain High temp grease to use? I know my cables are in great shape as I had the tank off 2 days ago and was poking around being bored
1992 FZR 1000
Re: Exup Grease
CopperSlip anti-seize
Re: Exup Grease
1K+ on that tip almost bullet proof where heat & lube are concerned.DonTZ125 wrote:CopperSlip anti-seize
Re: Exup Grease
Is there any certain place where this can be had at Don? I was in a Napa a few weeks ago looking at High temp grease as I knew the time was coming up to service it... and YG Im not sure I under stand
1k as in bike or 1k as in temp?
1992 FZR 1000
Re: Exup Grease
Well, I found mine in Canadian Tire - not sure if that's any help to you!
The guy at the counter should know what you're talking about when you ask for anti-seize.
Re: Exup Grease
They usually just call it "Anti-Seize Lubricant" or compound. Several companies like Loctite and Permatex make it. I use it on spark plug threads.
FWIW, it's "Copaslip", not "Copperslip".
Re: Exup Grease
No 1000 brownie points for the Tip of using copper Kote.McFizzer wrote:Is there any certain place where this can be had at Don? I was in a Napa a few weeks ago looking at High temp grease as I knew the time was coming up to service it... and YG Im not sure I under stand1k as in bike or 1k as in temp?
Re: Exup Grease
ah hah! now I getcha. Tomorrow shall pose as good day. Detailed her yesterday after riding in some down pouring weather grhhh. now to get it tip top
Apperciate the input guys. I tried searching but couldnt really find anything. i did however print out the write up on exup maintance which I thought was done great. the link was around her or on the archives or exupworldwide somewhere.... so many damn forums i get lost
1992 FZR 1000
Re: Exup Grease
thank You
Re: Exup Grease
I printed it out and its at home George. Currently out fixing my front fender. When I get home I'll look for the url on the page and post it for you unless i have it saved.
1992 FZR 1000
Re: Exup Grease
actually thats the think that Don posted. disregard my last post
1992 FZR 1000
Re: Exup Grease
Copaslip isn't as effective as this stuff. its not the cheapest stuff on the planet...but its worth it!
Re: Exup Grease
Stig can that be had in the US?
and how much does it usually run?
1992 FZR 1000
Re: Exup Grease
Its made by Bostik an american company so try McMaster CarrMcFizzer wrote:Stig can that be had in the US?and how much does it usually run?
