Fairing air intake pipes?
Just wondering, because ive seen in some pics people removing these pipes (even on race bikes) I would've thought that was a bad idea because im very surprised at the amount of heat that comes out under the tank. Its not that surprising though because the radiator only moves the heat from the engine to the radiator. The heat then goes back and up under the tank.
Or is it OK to remove them? I wont be regardless of your answers, just curious. Cheers.
- Kevadlilleke
Re: Fairing air intake pipes?
Hot air shouldn't get from the radiator to under-the-tank, because of the cover under the coil bracket. But I'd assume that having the intake pipes fitted would help keep designed air pressure around the airbox intake.
2012
2013
2014
2012
Many newer bikes use forced air intake fed into the airbox to pressurize it.
My layman's understanding is that it acts like a supercharger, and forcing more air in increases power.
2000 VFR800, 1998 VTR1000, 1996 Bandit 600, 1998 FZR600, 1998 DR350SE
Going slow into a corner, and coming fast out is good. Going fast into a corner and coming out dead is not good.
If these are the tubes I think you're talking about, I believe they cool the frame, and do not have an opening to the engine compartment or the air box
My FZR6 Rebuild
My FZR6 Rebuild
Its to keep the carbs cooler and electrics.
Forget it.
Forget it.
- Kevadlilleke
No, it merely compensates for underpressure that normally forms under the tank when you drive at highway speed and also acts as fresh/cool air inlet. As a sidenote - FZR doesn't have ram-air, just some pressure equalization, but it is still there to help the airbox design work as intended.FTL900 wrote:My layman's understanding is that it acts like a supercharger, and forcing more air in increases power.
On the FZR 1000 (at least) they go through the frame and end right inside the frame, above the engine block. No direct connection to the airbox, but to the cavity between the engine, tank and airbox - which is where the airbox takes air from.Genesis wrote:If these are the tubes I think you're talking about, I believe they cool the frame, and do not have an opening to the engine compartment or the air box
In principle when the pipes are in place, you should have a bit smoother ride and a bit more fuel economy because the airbox resonates at its engineered frequency. Any power gains shouldn't be noticeable outside the racetrack.
2012
2013
2014
2012
- Kevadlilleke
More reading...
Light:
http://www.thunderproducts.com/AirboxesDynotech.htm
http://www.superstreetbike.com/howtos/0 ... ewall.html
http://www.ducati-upnorth.com/tech/airfilter.php
More technical:
http://motorcycleinfo.calsci.com/Airboxes.html
Random:
viewtopic.php?f=7&t=11143
Light:
More technical:
Random:
2012
2013
2014
2012
Re: Re: Fairing air intake pipes?
Interesting. wonder y they did not do it on the 600.On the FZR 1000 (at least) they go through the frame and end right inside the frame, above the engine block. No direct connection to the airbox, but to the cavity between the engine, tank and airbox - which is where the airboxGenesis wrote:If these are the tubes I think you're talking about, I believe they cool the frame, and do not have an opening to the engine compartment or the air box
My FZR6 Rebuild
My FZR6 Rebuild
This is an interesting subject, I doubt very much the air intakes are to cool the frameGenesis wrote:Interesting. wonder y they did not do it on the 600.On the FZR 1000 (at least) they go through the frame and end right inside the frame, above the engine block. No direct connection to the airbox, but to the cavity between the engine, tank and airbox - which is where the airboxGenesis wrote:If these are the tubes I think you're talking about, I believe they cool the frame, and do not have an opening to the engine compartment or the air box
- Kevadlilleke
And by the looks of it, the pipes on the 600 go through the frame ( http://i.ebayimg.com/t/1990-Yamaha-FZR6 ... ~60_35.JPG ) Have you looked on the inside of your frame? Are you sure there are no openings?
2012
2013
2014
2012
Omy I never noticed, they come in just in front of my coil and right on the opposite side.
My FZR6 Rebuild
My FZR6 Rebuild
I don't know that much about these bikes, and I haven't read the links provided. I doubt there is much of a vaccum at all under the tank where the air box sucks in, theres plenty of room for air to get in there. The size of the hole in the airbox compared to the size of the gaps around the tank isn't even close. No one has mensioned loss of power due to carburettors heating up. Arent these bikes meant too have insulation between the bottom of the carbs and the block theyre sitting on? Surely these pipes are too provided fresh air around the carbs.
My 2 cents. Guessing.
Cheers.
Cheers.
- Kevadlilleke
Vacuum (or in that case just a slight underpressure) happens naturally at highway speeds under the tank because of aerodynamics. It's the same effect you get when you open your car window slightly.
2012
2013
2014
2012
