and where the plugs go cause they came out
check it out here
Fizzinatorr wrote:All the fuses check out
hmm there's a fuel pump relay? or do you mean the starter relay?
also, where's the VR located on this model?
Actually, the clicking is the fuel pump if I'm not mistaken. I think that sound is burned in my head from listening to it for 13 minutes while my entire tank pumped out to test the flow.Fizzinatorr wrote:checked all wiring carefully, it's all good
so it's either the fuel pump or the relay, but the relay makes the appropriate clicking sound when i push from start to run so that means it's the pump itself
