New tires are on and wheels are painted flat black.
I also changed the oil seals on both forks. The manual says a tool is needed to hold the damper rod to keep it from spinning. I spent some time trying to figure out the size etc but ended up not needing one: put the fork leg into a vice and loosen the bottom bolt. Once that's done, put the fork with spring inserted on the ground with open side down. While applying pressure, use a power tool to unscrew the bolt all the way. The spring held the rod in place. Worked like a charm. Same procedure to tighten everything.
Unfortunately I ran out of fork oil and had to order. In the meantime, I put the rear wheel back on.
