troubleshooting
TroubleShooting Stories
Engine Won't Start
I went to start my fzr a while ago and go for a ride, it made about a half a crank and made a huge BAAANG !!! the starter would not budge the engine. I stripped the entire bike down thinking i was going to have to replace a camshaft or a timing chain…. i was wrong. as i looked down the intake boots just for inspection, i found # cylinder had about a 1/4“ of fuel sitting in the intake port, it was at this point i felt like a dumbass. I pulled # sparkplug and used my dental mirror and a flashlight to look through the spark plug hole and found that the problem was that # cylinder was hydro-locked with fuel. FACK!
I turned the ignition on, stood back and bumped the starter with the plug still removed and a geyser of fuel shot out of #1 cylinder. now i have to look into the # 1 carb and figure out why the float needle is not working. and change my oil now that it's full of gasoline. ~ MODKING
troubleshooting.1212446598.txt.gz · Last modified: 2020/10/19 11:48 (external edit)
