model_differences
 FZR400 Model Differences Model FZR400 FZR400R FZR400 FZR400R FZR400RR FZR400RR SP Mod code 1WG 2TK 3EN1 3EN2 3TJ1 3TJ2 3TJ6 / 3TJ7 Year 1986 1987 1988 1989 1989 1990 1992 / 1994 Length  2040mm 2040mm 2025mm 2020mm 1975mm 1975mm 1975mm Width  690mm 690mm 685mm 685mm 705mm 705mm 705mm Height  1125mm 1125mm 1160mm 1130mm 1090mm 1090mm 1090mm Wheelbase  1400mm ← ← 1400mm 1365mm 1365mm Seat high  785mm ← 760mm 770mm 760mm 760mm Ground clearance:- 135mm ← ← ← 125mm ← ← Dry weight  157kg 152kg 155kg ← 160kg ← ← Frame type Aluminium delta box Double cradle ← Aluminium delta box Press backbone
Caster 24°00 ← ← ← ← ← ← Trail 89mm ← ← ← ← 92mm ← ← Front suspension:-Uprighting telescopic ← ← ← ← ← ← Rear suspension:- Aluminium
             swing arm	Aluminium delta box	Aluminium delta box	←	←
	Link type       stabiliser,link         Swing arm
              mono cross	mono-cross		Link type mono cross
Front brake Double disk ← ← ← ← ←
Opposing 2 piston per caliper	Opposing 4 piston per calliper
Rear brake Single disk ← ← ← ← ← ←
Opposing 2 piston per calliper
Front tire size	110/70R 1753 H	←	←	110/70R 1754 H	120/60R 1755 H	←	←
Rear tire size	140/60R 1764 H	←	←	←	160/60R 1769 H	←	←
Engine type	4 stroke	←	←	←	←	←	←
	Water cooled
	DOHC
	4 valves
	Parallel 4 cylinders
Cubic displacement	399cc	←	←	←	←	←	←
Bore and Stroke	56.0mm×40.5mm	←	←	←	←	←	←
Compression ratio	11.5:1	←	←	←	12.2:1	←	←
Power output	59ps/12000rpm	←	←	←	←	←	53ps/12000rpm
Torque	3.9kg-m/9500rpm	←	←	←	4.0kg-m/9500rpm	←	3.7kg-m/9500rpm
Clutch type	Wet multiple plates	←	←	←	←	←	←
Transmission type	Return type 6 step	←	←	←	←	←	←
Primary gear ratio	2.170(89/41)	←	←	←	←	←	←
  Secondary gear ratio 2.933(44/15) 2.733(41/15) 2.894(55/19) ← ← 2.736(52/19) ←
1st gear gear ratio	3.31	2.46	3.31	←	←	2.46	←
2nd gear gear ratio	2.22	1.94	2.22	←	←	1.94	←
3rd gear gear ratio	1.71	1.63	1.71	←	←	1.63	←
4th gear gear ratio	1.43	1.5	1.43	←	←	1.5	←
5 fast gear ratio	1.27	1.37	1.27	←	←	1.37	←
6 fast gear ratio	1.17	1.25	1.17	←	←	1.25	←
Fuel tank capacity	18l	←	17l	←	15l	←	←
Fuel economy	53km/l	←	52km/l	←	50km/l	←	←
model_differences.1281810116.txt.gz · Last modified: 2020/10/19 11:49 (external edit)
