1993_fzr_1000_exup
Year1993
Capacity1002
Bore x Stroke75.5 x 56 mm
Induction4x 38mm Mikuni
Ignition / StartingFIXME / electric
Max power (rear tire)145 hp 105.7 kW @ 10000 rpm (rear tyre 133.4 hp @ 10000 rpm )
Max Torque10 kg-m. 98.1Nm @ 8500 rpm
Transmission / Drive5 Speed / Chain
Front Suspension43mm Upside-down forks, preload adjustable.
Rear SuspensionMonocross preload, compression and rebound damping adjustable.
Front Brakes2x 310mm discs 6 piston calipers
Rear BrakesSingle 240mm disc 2 piston caliper
Front Tire130/60 VR17
Rear Tire170/60 VR
Dry-Weight / Wet-Weight214kg / 231 kg
Consumption average17.1 km/lit
Braking 60 - 0 / 100 - 012.3 m / 34.5 m
Standing ¼ Mile10.1 sec / 216.5 km/h
Top Speed273.1 km/h
1993_fzr_1000_exup.1212194381.txt.gz · Last modified: 2020/10/19 11:47 (external edit) · Currently locked by: 216.73.217.74,10.8.105.140
