1990_fzr400_rr_and_sp
| Year | 1990RR | |
| Capacity | 399 | |
| Induction | 4x32mm Mikuni carbs | |
| Max power (rear tyre) | 60 hp @ 12500 rpm | |
| Front Suspension | 43mm telescopic forks | |
| Rear Suspension | Monoshock single shock preload adjustable | |
| Rear Brakes | Single 210mm disc 2 piston calipers | |
| Front Tire | 120/60 VR17 | |
| Rear Tire | 160/60 VR17 | |
| Dry Weight | 160kg | |
| Fuel Capacity | 15 Liters | |
| Consumption average | 36 mp/g | |
| Standing ¼ Mile | 13.1sec/101mp/h | |
| Top Speed | 122mp/h | |
| Year | 1990RR-SP | |
| Capacity | 399 | |
| Ignition | Electonic Digital Control | |
| Front Suspension | 43mm Upside-down forks with adjustable preload, rebound and compression damping | |
| Front Tire | 120/60-17 | |
| Rear Tire | 160/60-17 | |
| Dry Weight | 160 kg | |
| Fuel Capacity | 15 liters | |
| Standing ¼ Mile | 13.6 sec/100.5 mp/h | |
| Top Speed | 110.5 mp/h | |
1990_fzr400_rr_and_sp.1281763597.txt.gz · Last modified: 2020/10/19 11:47 (external edit)
