1988_fzr_1000_genesis
Year1988 FZR1000 (GENESIS)
Capacity989
Bore x Stroke75 x 56 mm
Compression Ratio11.2:1
Induction4x 37mm BDS Mikuni
IgnitionDigital / electric
Max power (rear tire)135 hp 100.8 kW @ 10000 rpm
Max Torque10.4 kg-m 102 Nm @ 8500 rpm
Transmission5 Speed / chain
FrameDouble cradle aluminium Deltabox
Front Suspension41mm Telescopic infinite preload adjustable. 130mm wheel travel.
Rear SuspensionMonoshock infinite preload adjust, 130mm wheel travel.
Front Brakes2x 317mm discs 4 piston calipers
Rear BrakesSingle 264mm disc 2 piston caliper
Front Tire120/70 VR17
Rear Tire160/60 VR18
Dry/Wer Weight204 kg / 215 kg
Consumption average15.8 km/lit
Braking 60 - 0 / 100 - 013.1 m / 37.6 m
Standing ¼ Mile10.7 sec / 204.97 kmh
Top Speed256.6 kmh
1988_fzr_1000_genesis.1212194944.txt.gz · Last modified: 2020/10/19 11:47 (external edit)
