troubleshooting
Differences
Link to this comparison view
Next revision
Previous revision
troubleshooting [2008/06/02 18:09] – 70.255.83.192troubleshooting [2020/10/19 11:51] (current) – external edit 127.0.0.1
Line 2: Line 2:
 ===== Engine Won't Start ===== ===== Engine Won't Start =====
-I went to start my FZR a while ago to go for a ride, it made about a half a crank and made a huge BAAANG!!! the starter would not budge the engine. I stripped the entire bike down thinking I was going to have to replace a camshaft or a timing chain.... I was wrong. As I looked down the intake boots just for inspection, I found # cylinder had about a 1/4" of fuel sitting in the intake port, it was at this point I felt like a dumbass.  +I went to start my FZR a while ago to go for a ride, it made about a half a crank and made a huge BAAANG!!! the starter would not budge the engine. I stripped the entire bike down thinking I was going to have to replace a camshaft or a timing chain.... I was wrong. As I looked down the intake boots just for inspection, I found #1 cylinder had about a 1/4" of fuel sitting in the intake port, it was at this point I felt like a dumbass.
-I pulled # sparkplug and used my dental mirror and a flashlight to look through the spark plug hole and found that the problem was that # cylinder was hydro-locked with fuel. FACK! +I pulled #1 sparkplug and used my dental mirror and a flashlight to look through the spark plug hole and found that the problem was that #1 cylinder was hydro-locked with fuel. FACK!
-I turned the ignition on, stood back and bumped the starter with the plug still removed and a geyser of fuel shot out of #1 cylinder. Now I have to look into the # 1 carb and figure out why the float needle is not working. And change my oil now that it's full of gasoline.\\  +I turned the ignition on, stood back and bumped the starter with the plug still removed and a geyser of fuel shot out of #1 cylinder. Now I have to look into the #1 carb and figure out why the float needle is not working. And change my oil now that it's full of gasoline.\\
 ~ MODKING ~ MODKING
troubleshooting.1212448173.txt.gz · Last modified: 2020/10/19 11:49 (external edit)
