tci-repair
Differences
| Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
| tci-repair [2011/06/17 09:41] – old revision restored 127.0.0.1 | tci-repair [2020/10/19 11:50] (current) – external edit 127.0.0.1 | ||
| Line 25: | Line 25: | ||
| - | Some new information: | + | ==== Some new information: |
| + | From this picture :- Top to bottom: | ||
| + | * Zener, unknown, | ||
| + | band left in the pic. " | ||
| + | * resistor Bl R Br Gd = 620, 5% | ||
| + | * resistor R R R Gd = 2.2k, 5% | ||
| + | The tach signal is tied into the 2-3 spark signal. The earlier model tachs simply picked up the fly-back pulse from the coil, while the newer tachs want a 12v or 5v signal from the TCI (not sure which voltage; this will very likely be tied into the Zener diode rating). | ||
| + | The tach may come back to life once you replace the TO-220 ignition transistor. | ||
| + | **//Info supplied by DONTZ125, | ||
| ===== Editted extras by Y-G & supplied by ReelRazor ===== | ===== Editted extras by Y-G & supplied by ReelRazor ===== | ||
tci-repair.1308321675.txt.gz · Last modified: 2020/10/19 11:49 (external edit) · Currently locked by: 216.73.216.42,10.1.138.54
