r1_rear_shock_swap
Differences
Link to this comparison view
Next revision
Previous revision
r1_rear_shock_swap [2008/09/18 17:02] – added content 64.216.47.206r1_rear_shock_swap [2011/03/07 15:29] (current) – removed 127.0.0.1
Line 1: Line 1:
-====== R6 Rear Shock Swap======
-**What you'll need:**\\
-  * 06-08 R6 shock (earlier years WON'T work without alot more work)
-  * Spacers
-  * Dog bones
-  * I also recommend a heavier spring for the fzr600, around a 650-750lbs, the stock r6(~500lbs) is perfect for the fzr400.\\
-**The Shock:**\\
-These can be picked up of eBay for next to nothing ~$25.00USD.\\ \\
-:!:You will need to round the lower shock mount so that it clears the suspension knuckle.:!:
-All of the R6 shocks that can be used for this conversion look like this\\
-{{:r6_shock_swap_1.jpg|2006-2008 Yamaha R6 Rear Shock}}
-This image dipicts were you'll have to grind the shock slightly so it clears the knuckle.\\
-{{:r6_shock_swap_2.jpg?180x197|Click To Enlarge}}{{:r6_shock_swap_3.jpg?180|Click To Enlarge}}
-**The spacers:**\\
-You need two of these spacers as the FZR shock is 10mm wider than the R6 and uses a 12mm bolt as opposed to a 10mm bolts.[ 10mm dia hole drilled through]FIXME. The green section needs to be 5mm wide, diameter doesn't really matter and can be anywhere from 14mm to 20mm. The red section should be just under 12mm dia and ~7mm long. For the FZR400 ignore the stepped down section on the left(red) as the FZR400 uses a 10mm bolt which is the same size as the R6, so you only need the green section.\\
-{{:r6_shock_swap_4.jpg?360|Click To Enlarge}}
-This is where they go\\
-{{:r6_shock_swap_5.jpg?360|Click To Enlarge}}{{:r6_shock_swap_6.jpg?360|Click To Enlarge}}
-**Dog bones:**\\
-~10mm short than the FZR dog bones, this raises the bike back near stock. 6mm thick.\\
-{{:r6_shock_swap_7.jpg?360|Click To Enlarge}}
-Stock on the left next to two new ones\\
-{{:r6_shock_swap_8.jpg?360|Click To Enlarge}}
-For the fzr400(3en1) I had to grind a tiny amount of the top frame mount although I didn't have an issue with the 600.
-{{  :comments.gif  |}}
--Dru86
r1_rear_shock_swap.1221775361.txt.gz · Last modified: 2020/10/19 11:49 (external edit)
