how_to
Differences
| Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
| how_to [2008/05/27 20:16] – 72.207.25.15 | how_to [2020/10/19 11:50] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| + | FIXME | ||
| ==== How to adjust your valve clearances ==== | ==== How to adjust your valve clearances ==== | ||
| This is incomplete but please feel free to edit this if you have knowledge on this matter | This is incomplete but please feel free to edit this if you have knowledge on this matter | ||
| - | * Difficulity: | + | |
| - | * Attention to detail: medium | + | * Attention to detail: medium |
| - | * Time: 6-8 hours (if you get the timing right) | + | * Time: 6-8 hours (if you get the timing right) |
| - | * Tools needed: socket wrench, small extension, 8mm, 10mm sockets, ice cube tray, magnet tool | + | * Tools needed: socket wrench, small extension, 8mm, 10mm sockets, ice cube tray, magnet tool, pen, paper |
| + | Once you have recorded the clearances and the shim sizes you want to use the shimulator to calculate your new shims. | ||
| + | There are two ways to perform this procedure and you'll need to decide which method is better for you. | ||
| + | The two ways of doing this are with the engine removed and the engine still in the frame. | ||
| + | Removed Pros: easier to access valve cover, shims, timing and everyting else. You might also find additional issues that you might not be able to find otherwise | ||
| + | Removed Cons: adds additional time and requires more tools. | ||
| + | * Remove valve cover (8mm) | ||
| + | * Remove chain guard | ||
| + | * Remove bridges one at a time | ||
| + | * Remove top right first, then top left, then bottom right, then bottom left | ||
| + | :!: You must loosen the bolts evenly starting with the middle bolts. | ||
| + | :!: Only loosen a few revolutions at a time. If you don't do this the bridge will break! | ||
| + | - icontender | ||
how_to.1211937407.txt.gz · Last modified: 2020/10/19 11:46 (external edit)
