1990_fzr400_rr_and_sp
Differences
| Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
| 1990_fzr400_rr_and_sp [2008/05/22 01:14] – 70.244.154.128 | 1990_fzr400_rr_and_sp [2020/10/19 11:51] (current) – external edit 127.0.0.1 | ||
| Line 9: | Line 9: | ||
| ^Max Torque^|4 kg-m @ 9500 rpm| | ^Max Torque^|4 kg-m @ 9500 rpm| | ||
| ^Transmission^|6 Speed| | ^Transmission^|6 Speed| | ||
| - | ^Front Suspension^|41mm Telescopic | + | ^Front Suspension^|43mm telescopic |
| ^Rear Suspension^|Monoshock single shock preload adjustable| | ^Rear Suspension^|Monoshock single shock preload adjustable| | ||
| - | ^Front Brakes^|2x 298mm discs 2 piston calipers| | + | ^Front Brakes^|2x 298mm discs 4 piston calipers| |
| ^Rear Brakes^|Single 210mm disc 2 piston calipers| | ^Rear Brakes^|Single 210mm disc 2 piston calipers| | ||
| ^Front Tire^|120/ | ^Front Tire^|120/ | ||
| Line 33: | Line 33: | ||
| ^Transmission^|6 Speed | | ^Transmission^|6 Speed | | ||
| - | ^Front Suspension^|43mm | + | ^Front Suspension^|43mm forks with adjustable |
| ^Rear Suspension^|Monocross with adjustable | ^Rear Suspension^|Monocross with adjustable | ||
| ^Front Brakes^|2x 298mm disc 4 piston calipers| | ^Front Brakes^|2x 298mm disc 4 piston calipers| | ||
| Line 48: | Line 48: | ||
| + | http:// | ||
1990_fzr400_rr_and_sp.1211436888.txt.gz · Last modified: 2020/10/19 11:48 (external edit)
