hemets
- Level 3.0
hemets
i have a element fastrack helmet from o'neal with a bluetooth system in it. i have been looking for a battery to go with it and can not find what i need anywhere and it is driving me nuts. i am looking to wire in a phone charger in the trunk and put my phone on it so that i can ride to work next month with out having to have headphones in and be able to charge it. does any one know where you can get bluetooth batteries?
Re: hemets
Is it a Lithium Ion battery? If so, you can simply check eBay if you know the voltage and mAh of the current battery. Probably a solder in battery unit.
darrin
darrin
- Level 3.0
Re: hemets
its a little weird it doesn't say what kind it is or the volts. it just has a model number and a frequency rating. and no matter where i go i cant find a model number. i pulled it apart to check to see if the pins could be pulled to put in another battery but i didn't see any damage or over heating marks on the circuit board at all.
