After searching it seems like OEM, Barnett, or EBC are the brands.
I don't need to upgrade to HD Springs as long as the Stock Spring rates won't cause clutch slipping; I ride in traffic often and don't need my left hand to be stronger..
What are your Clutch reviews? Recommendations? and Experiences?
Thanks!
**** **** Back Story / Details why i'll be replacing the Clutch: **** ****
So i've only owned my bike for a month or two, but anytime i really get into the high revs (especially in higher gears) the RPMs spike but the Bike barely accelerates... Really annoying and way worse with the girl on the back...
Anyway: Yes, obviously the Clutch is Slipping.
-I have adjusted the clutch linkage both near the front sprocket and at the handlebar.
-I have changed the oil; 20w50 Dino Motorcycle Oil is in it
-Its seems to be slightly better when the bike is warm
The bike has about 17k miles on it. The Front Suspension is pretty soft, chain was badly stretched, and the clutch slips... Sounds like the PO may have practiced some wheelies on this bike... ?? ....
I have no problem changing the clutch, i've done it on bike before. BUT want opinions on Clutch options.
