Black smoke
kryzhkov
Black smoke
Post by kryzhkov »
Alrighty, so I started her up. Warmed up fine, revved her a little high, plume of black smoke puffed out, and now won't start.. hah what did I do to her?!
cowboi
Re: Black smoke
Post by cowboi »
Sounds like its rich. Might wanna pull the plugs and check them.
78 CB750A
96 FZR600R
00 YZF R1
04 YZF R6
kryzhkov
Re: Black smoke
Post by kryzhkov »
Nooo! I literally ran her twice since I changed the plugs. Crud :[
88FZRMAYHEM
Re: Black smoke
Post by 88FZRMAYHEM »
kryzhkov wrote: revved her a little high
how high is "a little high" ??
88FZRMAYHEM
Re: Black smoke
also where u at in NC .. im in king just north of winston salem
kryzhkov
Re: Black smoke
Post by kryzhkov »
I revved her up to 8.5 grand.
Oh really now?! I live In lewisville area. I went to Reagan High School. I definitely know where king is. I used to go down to the RC track all the time over there. Wow, this is really cool! I could definitely use someones help :P
sweekster
Re: Black smoke
Post by sweekster »
Yeah thats a rich condition for sure. Might be time for a synch.
crowe
Re: Black smoke
Post by crowe »
sounds like its runnin rich and ya carbs need balancing, new air filter too to make sure the right air/fuel mix is getting through. also in addition i got a bit of black smoke when i reved it hard untill i repacked my end can. the old wadding in the end can was saturated with soot, oil, and god knows how many years worth of other shite. the minute i repacked it the black shite stopped!!
1994 FZR1000EXUP RU
1994 VFR750FR
1998 GSXR600SRAD
1988 CBR600
2001 FAZER600
2001 HORNET 600
1987 VFR400Z (NC21)
1998 TZR125
1987 RD125LC MK2
pefrey
Level 5.5
Level 5.5
Re: Black smoke
Post by pefrey »
How big is a plume of black smoke? It differs for everybody. If it won't start after the plume, that's not a good sign. Was it jet black or more dark gray? Was there any unusual noise with the smoke, or just a plume and the engine stopped as though you turned it off, or did something go bang.
lawmer
Re: Black smoke
Post by lawmer »
cowboi wrote:Sounds like its rich. Might wanna pull the plugs and check them.
kryzhkov wrote:Nooo! I literally ran her twice since I changed the plugs. Crud :[
Mod edit - comments not helping, and not warranted by the conversation so far. DonTZ125
OK so what plugs did you install? I do however believe my comment was valid, since so little info has been supplied, yet.........
Usually the last thing you did is the first thing to check, it is in my book :whistle
lawmer
Re: Black smoke
Post by lawmer »
Just so everyone knows - the reason cowboi said "Might wanna pull the plugs and check them."
is..... yes, the condition of them brand new or not tell's you alot of whats going on in each cylinder.
imo the first reply was exactly what i would have done on a customers bike (regardless of what the customer said, otherwise he would take his bike home). Then I would make sure the plugs the customer had installed were of the correct heat range.
The OP's reply to the first post
well... you can read it.
but cowboi :cheers: had the right idea and was blatantly shunned!
bokka
Re: Black smoke
Post by bokka »
hi after checking the plugs and air filter do a compression test on each cylinder it should be between 9.99 bar and 11.29 bar..(145 psi and 164 psi).fzrs are prone to valve problems..if this is ok its your carbs...
kryzhkov
Re: Black smoke
Post by kryzhkov »
I installed NGK cr9's.
the bike ran the next day perfectly. I have no tools to check the psi, but I know the previous owner was not big on maintenance.. It probably needs a valve job.
do you all know a good place to buy somewhat cheap carb sync tools? my fzr manual is still on the way.. so far I have been doing the best as I can with the help of this forum haha.
sweekster
Re: Black smoke
Post by sweekster »
