Fox Twin Clicker Rebuild
Hey Modking, thatkid and I are planning on rebuilding our shocks this winter. I checked your old thread on the archives but the photos were removed. I got the manual off the archives as well but I figured you may still have the pics from when you worked on yours. And I may have some questions in the future as well. I know you put a new spring on yours and I'm wondering if I should have to do that as well or will my spring be sufficient? Or is it hard to tell w/e seeing the shock? I hope this is a good place to post this, but i'm not sure if you don't like people creating new topics in your section. If that is the case feel free to move it.
Upgrades:
- ShogunTX
- Level 4.5
Re: Fox Twin Clicker Rebuild
This would be helpfull for the WIKI ask I just shelled out 170.00 to Fox to rebuild mine. If you have pictures to go along with the write up let me know! I as I plan to have several rebuilds over the next few years.....
Check with Mark (msilves). He just got finished rebuilding his shock. I think he took photos. Said it was a lot easier than he thought it would be.
Also, both of my Fox shocks have Hypercoil springs on them.
Since you're in a lower weight class than me, Zero, you'd probably be fine with the stock Fox spring. They talk about the different springs that were available for the FOX TC in the manual.
ragedigital wrote:Check with Mark (msilves). He just got finished rebuilding his shock. I think he took photos. Said it was a lot easier than he thought it would be.
A while ago in my shock thread you said there was a guy who was going to post pics of his shock. What happened with that? I think I have a WP not a FOX now that i posted about it but it is unconfirmed.
Upgrades:
I doubt that you have a FOX. Doesn't look like either of mine.
I invited the guy, who's part of the local motorcycle forums here in St. Louis, but he hasn't responded.
Send your pics to WP and see what they say.
darrin
darrin
