stock carb settings
stock carb settings
Hey everyone just moved back to ohio from florida and the alt messed up the carb setting and im bringing it back to stock what are the stock setting for theses carbs
Re: stock carb settings
Each carb is set individually - that is why they cover them up the IMS (Idle Mixture Screws) with brass plugs at the factory. You can start at 3 turns out - that seems to be a good starting point for most.
I start with 3 turns out and tweak it as necessary.
1991 FZR600 w/ YZF VR Upgrade, Twin Headlight conversion
1981 XS400 Cafe build.
Can't ya tell I like Yamahas?
