I would like to replace the alternator bearing in my fzr 1000 genesis (1988) and I've got a problem: there is an alternator drive shaft that I should to remove with bearing. So heare is my question: can I knock out the shaft with bearing at once? Or maybe before I must to remove starter idle gears ?
Thanks!
Wojtek
