A while back (about 2 months ago) I adjusted the clutch on the bottom and then at the top like instructed and my upper adjustment has never been the same. The last month or so when I take off from 1st gear from a stop I hear a pop like the push rod is not going all the way in or something. Could that be that I need to adjust it better from the bottom or do I need a new clutch and push rod?
I started reading up on the lower adjustment and It says I need to run the bottom in clockwise all the way and then back it off 1/8-1/4 counter clockwise and then go to the top and adjust. Does that sound right? I will try it this weekend but if any of ya'll have any suggestions I'm all ears.
I need Clutch assistance
Re: I need Clutch assistance
when I adjusted my clutch down below i didnt do it up top at the same time. I just backed the screw out down below probably a little more than 1/4 of a turn after tightening it then tightened the 12mm nut back up and kept doing that while adjusting the top, I never adjusted both at the same time.
beginning
middle
most recent
93 fzr 600:
r6 brakes
r6 exhaust
flush mount signals
custom stock fzr tail trimmed and fiberglassed by mxryder
520 conversion
middle
most recent
93 fzr 600:
r6 brakes
r6 exhaust
flush mount signals
520 conversion
Thanks! I dont know what happen but I think I got it. Will know more tomorrow when I ride the bitch all day.
