I bought it from someone who had garaged it and was not actively riding it. The issue that I am having with it are cold starts and idling. When it is cold (I am in California so it doesn't get really reallycold here) and I try to start it, it does not start without the choke on. Now I know that is normal but I have to use the ignition three to four times to get it started and each time its 7 to 10 seconds. After I get it started I let it run on choke for a few minutes to get the engine warm. I usually adjust the choke down half way to get the RPMs down to about 2000. Now if I turn the choke completely off, the bike slowly starts to loose rpms and idles really low around 1000 and slowly starts getting lower and lower until it stalls. So in order for it to stay on, I have to constantly give it a throttle. After it stalls, I can start it again very easily since its warm and don't require the choke anymore.
I had been reading this forum for the past few days and figured there was an issue with the carburetors and they needed cleaning. I found a mechanic on craigslist and worked out a deal with him to clean the carbs. He came, took them out and cleaned everything. The carburetor actually looked very clean to me and he also remarked that none of the jets and floats seemed dirty but he still cleaned everything with carb cleaner. After cleaning and putting everything together, we started the motorcycle again and let it warm up. He also adjusted the idle screw on the carb and after the adjustments, the bike seemed to idle without the choke and without me giving it a throttle. But the idling was not smooth. The rpms varied a little bit and the rpm pin wasnt completely smooth and steady, but at least the bike wasn't stalling. I paid the guy 80 bux from my cash strapped student budget and thought I was in a decent spot.
Now after a few hours, I started the bike again and realized that it was exactly like it used to be before. Starts only with choke and slowly stalls if the choke is off and I dont give it any throttle.
I am guessing that it needs its carbs synced? The fact that the idle pin was not smooth and varied up and down slightly might be the timing difference in the butterflys?
I am not really good with tools and have not tinkered around with motorcycles before so dont really trust my abilities on the bike. I was wondering if you guys had any thoughts about what could be going on? I talked to a mechanic and he said he would charge me 200 bux to get it fixed but that is well beyond my current budget. Any advice or help from you guys would be greatly appreciated.
