Recently changed my clutch with a complete kit from EBC (friction plates/steels/springs). Replaced both push rods and the small steel bearing and fitted a new clutch cable. I also saw that the original clutch push lever assembly had broken tabs on the outer face so I replaced it with a better second hand one.
This impoved things as the old clutch was slipping slightly before. However, I cannot seem to get the clutch bite point right, and gear change performance varies, sometimes smooth sometimes rough, previously it was quite positive.
I have done the adjustment at the push lever assembly end (loosened cable right off, turned bolt in until lightly touching and backed of 1/4 turn and later took it out some more). Adjusted at the lever for 2-3 mm play at the lever butt.
Today I took the clutch push lever assembly off again and found the same two small tabs broken (does this really matter?). I am out of ideas now, is there something obvious that I'm missing?
