Battery confusion
- deathcomesarippin
Battery confusion
So I need a new battery... the old one isnt holding a charge. I went up to discount auto parts... after about 20 minutes of searching, they can get me one from another store, for about 75 big ones . The walmart near me dosent have a battery for a FZR, but they have a battery for a YZF ,same engine size (600) ,and same year (95) and for only $34. Does antbody know if that will work? It looks about the same but I dont want to risk it. Could use some advice.
modded air box,
K&N drop in,
race tech fork springs,
R6 header-kerker exhuast,
things to come, 520 conversion, jet kit, yzf front brake calibers
K&N drop in,
Re: Battery confusion
Try batteries plus store around you they should have a battery for you.
it;s the number on the battery you need to look at, assuming they are the same as over here!
normally something like ytx 9ah, its the 9ah that tells you the cranking power. if the numbers match it should be up to the job.
there will be variations in the letters before it depending on the manufacturer.
just make sure it isnt any bigger than the battery box!
Fzr400 3tj x2
'94 cbr 900rr
'94 cbr 900rr
Buy a walmart battery and you end up replacing them every couple years (at best).
The FZR battery has it's terminals in the reverse configuration than most. This is why they are priced up a bit. Get the same battery case size with the common terminal setup and reroute your battery leads (have to clip cable ties under/around the battery box).
Seems like I paid about $52 for a genuine Yuasa with terminals reversed from the FZR norm and saved myself about $20.
Whatever you do, make sure you charge it fully (low amps-long time) BEFORE using it. The very first charge pretty much determines the lifespan of the battery. Run it, and check the fluid levels after about a week0it WILL need topping up.
A good battery, with a minimum of maintenance will last for years and years.
- deathcomesarippin
Alright thanks for the reply, you both helpd out!
modded air box,
K&N drop in,
K&N drop in,
- deathcomesarippin
Better be safe than sorry but is this the battery im looking for?
http://www.batterymart.com/c-yamaha-fzr ... al-a2.html
modded air box,
K&N drop in,
K&N drop in,
What's wrong with the Wal-Mart battery? I'm on my 4th year with one. I expect I'll get plenty more out of it.
The reversed terminals mean that it has to be hooked up in the battery tray, but that is not a big problem. The overflow pipe will also be on the wrong side, but again that is not a big issue -- just route it similarly.
Darren
Darren
- deathcomesarippin
alright, and all the walmarts ive been to dont carry a fzr battery, so I just got it from the website.
modded air box,
K&N drop in,
K&N drop in,
I was just at walmart looking at the batteries and its the 12bs. At my walmart it was $57.97.
78 CB750A
96 FZR600R
00 YZF R1
04 YZF R6
78 CB750A
96 FZR600R
00 YZF R1
04 YZF R6
They don't carry one specifically for the FZR. They DO carry one in stock that is identical, EXCEPT the terminals are REVERSED.
My point is the reversed terminal battery WILL fit an FZR (the cables DO reach, but it is a minor pain because the battery must be fully down in the battery tray before hooking it up). It is substantially cheaper than a "proper" FZR batttery, and will last just as long.
Hey, I'm just trying to save you money...
Darren
Darren
