93 FZR 600 not starting
So I got caught in the rain a couple weeks ago and my bike back fired a couple times and shut off. I haven't been able to get it to start since. I've drained the gas, drained the carbs of the gas that was in them, sprayed some ether in the carbs and air box to dry the water, replaced the spark plugs and I still can't get it to fire up. Any suggestions?
*1993 FZR600*
Re: 93 FZR 600 not starting
Disable the kickstand safety switch, had the same problem with my seca 2, that switch sees a lot of water in the rain. Aside from that I would start testing the ignition system component by component.
96 fzr600. R1 body kit.
94 xj600 seca 2: complete upgrade restoration.
73 Honda cb750 four: bored out 178 over (850 cc) street cam, smoothbore carbs, velocity stacks, corbin king-queen seat, 4-1 header with modified megaphone exhaust, dyna-s ignition, too many other mods to mention and still under construction.
72 Suzuki ts90 cci. First bike ever, bone stock and still starts with 2 kicks.
Found out I'm not getting spark, going to replace the coils.
*1993 FZR600*
Be sure to test them first. Like the previous poster stated, it could be linked to something that is preventing the coils from getting voltage.kbarela wrote:Found out I'm not getting spark, going to replace the coils.
