quick carb question....might just need little tuning??
fresshmode
can anybody tell me why carb on cylinder three dosent flutter up with the others dosnt move much at all.. does it just need a adj. pretty simple question i hope.
Re: quick carb question....might just need little tunning??
If you mean the slide doesn't move as you blip the throttle, this is bad - you're basically running on 3 cyls. It probably means there is a vacuum leak to that slide, and it isn't being drawn up.
Strip the upper part of that carb - look for obstructions, plugged passages, gunge in the slide track / on the slide, missing o-ring at the top of the body, dead mouse holding the slide shut. Worst case is a torn diaphragm - $$!!
fresshmode
Just checked top carb had a slice in the rubber bladder part would that be my problem
"Well, that's your problem right there!" Crap..
There was a recent thread where a fellow repaired a SMALL hole in a slide diaphragm, take a look for it. There is a product my wife found recently called 'Liquid Electrical Tape', a paint-on rubber coating.
Try it - you can't be worse off than you are now.
Hi,DonTZ125 wrote:"Well, that's your problem right there!" Crap..
an actor friend of mine repaired his carb diaphragm with a tiny piece of facial tissue and make up artist latex rubber (the stuff they make up false scars etc with ), knowing him since it worked i doubt he replaced the diaphragm saved the money for his favourite single malt <BG>
