Anyway I need some help with questions so I don't jack something up. I did a search and didn't find any of my questions answered very well. Also the ipod doesn't pull up searches to well either.
In this first pic the T on the stator is lined up with the back of the crank on the little rectangle part that sticks out (sorry don't know the name). In the manual the picture it shows is actually upside down, but I wanted to make sure this is correct.
Also the manual says that when the stator is lined up like this and the cam rollers thin parts are pointed away from each other (3 and 9 o'clock.) [picture 1 in my 4th picture on here] However since our bikes have waste spark this happens 2x in the revolution of our motors correct? How do you know when cyl 1 is TDC? And it's not cyl 4 at TDC?
In this picture and the one that follows the rollers are pointed away from each other and there is a little nipple on the cam that is pointed mostly upward. Is that an indication that cyl 1 is TDC or is there a nipple on the top and bottom of the cam? In the manual when you are reinstalling the cams it says to make sure to line the nipples up just like they are now.
This is the picture from my manual in the first pic is has the rollers are opposite of each other, just like I have in my pic. Now, in the second pic in my manual is has the rollers turned so that the thin part is facing "up". Do you check the clearance with the roller like the first or second picture. Or does it even matter the valve is closed as long as the thin part isn't touching the keeper. However the cyl wouldn't be at TDC if I rolled the engine over to make the rollers look like they are in picture 2.
My final question is probably the most noob of them all. When moving down the cyls to check the clearances you have to keep rolling the engine over correct? to make sure each cyl is at TDC and the roller isn't pushing the valve down? I'm guessing so since the 4th pic in the pic of my manual shows when each cyl is in combustion and at what degree you have to move the engine to.
Finally I wanted to add that there were a few people looking for shim calculators. I tell you what in my manual there is the easiest thing ever to follow to make sure you put in the correct new shim. It's like an old multiplication table. My 15 year old cousin could follow it. Haha.
Thanks in advance,
Chris.
