Stock frame color
- rustyabiding
Stock frame color
Does anyone know what color gray is the stock fzr 600 frame color? I want to touch up some scratches.
Re: Stock frame color
Check the WIKI or http://www.saltmine.org.uk/fzr/fork.htmlrustyabiding wrote:Does anyone know what color gray is the stock fzr 600 frame color? I want to touch up some scratches.
in the latter you need if memory serves to read the last paragraph
- kiki231
if you are looking for color out of a rattle can, i have found that Honda heather mist metalic by duplicolor is bang on-- surprisingly i used it for the silver painted case covers too-- i use a clear over top for protection.
When things get expensive, I become a fast learner...
[i]1989 FZR600
2009 R1[/i]
[i]1989 FZR600
2009 R1[/i]
I had the Honda YR508M Heather Mist mixed into a rattle can to try a puff test on the rear subframe and found whilst close it's not grey/ gray enough, kinda a bit smokey.
The peugeot aluminium, which in hindsight I should have tried first is pretty much spot on.
Anyone have any suggestions for the bright red and blue on a 3he genesis side panels?
Cheers,
John
Cheers,
John
If it ain't broke, fiddle with it until it is.
1990 FZR600 Genesis 3HE
1993 Alfa Romeo
2008 Fiat
1993 Alfa Romeo
2008 Fiat
