hanging front end?
hanging front end?
Where is the best place to attach to the bike to hang the front end for suspension work?
97 FZR 600
91 KLR 650
91 KLR 650
Re: hanging front end?
Pretty much anywhere under the frame is just fine to hang the front end. I've picked it up with a strap under the steering neck before and that worked pretty well. Also if you have jack stands put them under the lower frame sections and that should get the bike up plenty high.
02 R6 Front End
Ducati M900 Seat/Taillight
Honda VFR750 Swingarm/Wheel
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
Cool thanks, I didn't think about the use of jack stands under the frame sections that seems like it will help a lot.
97 FZR 600
91 KLR 650
91 KLR 650
When I hung mine, I removed the "ram air" tubes from the frame and put the hooks from my ratchet straps in those holes.
Not sure what they're called, but they have the appearance of "ram air" tubes, just not the function.
+1 to ragedigital for hanging from the air tube holes in the frame. I put the hooks on the hole inside the frame facing the carbs. This allowed me to do frame paint touch up too.
Rotortech
Indianapolis, IN
[list]RaceTech Springs
R6 Rear Shock
FactoryPro Jet Kit
Indianapolis, IN
R6 Rear Shock
FactoryPro Jet Kit
Hanging & jack stands gives greater stability when working especially if you use a paddock stand on the rear !
I have picture of how I did mine on my site on the suspension related pages .
Thank you all Its good to get feedback and save some precious time, and possible damage
97 FZR 600
91 KLR 650
91 KLR 650
