Signal Flasher Replacement
So I'm pretty sure my flasher is bad and would like to replace it with a load independent flasher. Only problem is that there are five wires associated with the stock flasher and most aftermarket flashers have only two prongs. I already looked at the wiring diagram and used the search but there isn't really anything about changing the flasher. I know people have done it, but I can't quite figure it out. What have you guys done?
02 R6 Front End
Ducati M900 Seat/Taillight
Honda VFR750 Swingarm/Wheel
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
Re: Signal Flasher Replacement
The problem is the "flasher relay" also controls the self-cancelling function, keeping track of how long the blinkers have been on and how far you've travelled. I *think* you could get away with just the Br and Br/Wh wires for a 2-wire rig, but you'd have to modify / change the connector.
I can live without the self cancellation. I rode the bike around for a couple months before I even realized that the blinkers cancelled themselves! So which one is the load and which is the ground?
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
Brown goes to the relay, Brown/White goes from the relay to the switch to the bulbs to ground.
Go to Corsa-Technic.com , get their D6AP plug - http://www.corsa-technic.com/item.php?i ... gory_id=57. That will plug directly into your harness in place of the Yamaha relay; from there, just connect a typical Wal-Mart / Canadian Tire automotive relay socket.
Or you could buy a replacement for $14 off this guy - http://cgi.ebay.com/ebaymotors/80s-00s- ... 0510916472
