alternator amps ???
sleepyz0mby
alternator amps ???
Post by sleepyz0mby »
How many amps is the fzr 1000 able to provide? I've called around and the Yamy folks only give me serial numbers for parts...
reelrazor
Wrench
Wrench
Re: alternator amps ???
Post by reelrazor »
it is going to be in the 20 amp range after the voltage regulator.
More specifically,in tip-top charging system shape it will put out about 280-320 WATTS-if adding accessories is why you need this info, this number will be much more informative.
