R6 parts... Should I pull the trigger?
So on a local forum I found someone parting out a complete 2002 R6. I talked to him and I can get the entire front end, swingarm (and associated hardware), rearsets, and the header for $400. I would still need to buy a rear wheel, bars (clipons are fine though), and I'm sure other miscellaneous bits and pieces along the way. My question is, should I go for it? Thanks guys.
02 R6 Front End
Ducati M900 Seat/Taillight
Honda VFR750 Swingarm/Wheel
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
Re: R6 parts... Should I pull the trigger?
What are you waiting for?! Pounce on that like a lion on a baby elephant!!
'90 FZR600
Metallic Cobalt Blue plastics with a Black hammered finish frame.
Vance & Hines Supersport Header
'01 Honda Superhawk Tail
'09 R6 exhaust can
'07 R6 rear shock
'02 Ford Ignition Coil
'97 YZF Voltage Regulator
Factory Pro Jet Kit
Vortex Front and Rear Sprockets
RK Chain
UNI Air Filter
All lighting except headlights switched to led
Hot Cams Valve shims
Dominator Headlights
Vapor All in One Gauge
Custom Shorty Windscreen
Lots and lots of stainless and aluminum from ACE Hardware!
Dream list - New tail with custom led light and undertail. HID headlights. USD forks. Factory Pro emulsion tubes.
'09 R6 exhaust can
'07 R6 rear shock
Factory Pro Jet Kit
RK Chain
UNI Air Filter
sounds like a steal to me
Upgrades:
That's what I'm thinking too. Looks like I'm going to have some parts up for sale to fund the winter build. Thanks for the input.
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
What do you mean "entire front end"? If you mean:
left and right handle bars and clip ons
brake master cylinder lines and calipers
forks unbent / undamaged left and right
triple tree, top and bottom with stem
wheel with rotors
axle with spacers
front fender
then I say go for it. IMO don't bother with the other stuff, too much effort for too little gain and drop him down to $300 on the front end.
wheel with rotors
axle with spacers
front fender
I meant the entire front end minus one handle bar and the front fender. Everything else is there. I think i'm just going to get it all. Worst case scenario I can throw the swingarm and my soon-to-be extra R1 master cylinder on ebay or an R6 forum and make a little bit of cash back.pefrey wrote:What do you mean "entire front end"? If you mean:
wheel with rotors
axle with spacers
front fender
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
I'm with 'pefrey', the front end is where it's at. The R6 swing arm swap can be a money pit.
And if you need the stems swapped you can send them my way!
Nate, So the 2002 R6 front end is not a direct bolt on?thatkid wrote:And if you need the stems swapped you can send them my way!
That's what I've read anyways, also are the forks shorter?
I have access to a full machine shop through my school's formula car team so pressing the stem shouldn't be an issue. I might have some stuff for you to powedercoat over the winter though. I will get back to you on that one.thatkid wrote:And if you need the stems swapped you can send them my way!
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
02 R6 Front End
No Spacer 660
YZF600 Tank
Renthal Dirt Bars
Too much else...
mawler wrote:Nate, So the 2002 R6 front end is not a direct bolt on?thatkid wrote:And if you need the stems swapped you can send them my way!
That's what I've read anyways, also are the forks shorter?![]()
Nope, no R6 swap is a direct bolt on. And as far as I know, all of them are shorter than stock.
Well then, can I send YOU stuff??blensen wrote:I have access to a full machine shop through my school's formula car team so pressing the stem shouldn't be an issue. I might have some stuff for you to powedercoat over the winter though. I will get back to you on that one.thatkid wrote:And if you need the stems swapped you can send them my way!
Just let me know on the powder. My bigger oven is almost done!
