400/600 shock swap issues?
haunter
Post by haunter »
are the shocks the same length?
One of my dogbone customers isnt sure if he needs a non stock size set of dogs to swap shocks and keep the stock ride height and since I dont have both shocks laying around I don't know, I only know the stock dogbones are the same length!
bweight
Level 4.0
Level 4.0
Re: 400/600 shock swap issues?
Post by bweight »
From what I've read, the shocks are direct bolt in's.. I could be definitely wrong, but that's what I've come to understand
89 FZR 400
Custom Paintjob
600 plastics.
06 - R6 Shock
FZR600 Motor
Soon to be:
Broke........
ragedigital
4000+ Posts
4000+ Posts
Post by ragedigital »
I've switched mine back and forth with no problem. The Fox Shock fit both the 400 and 600.
That doesn't mean that the dog bones are the same. I had to use longer ones to make the shock work on the 400. Dang spring was too large.
haunter
Post by haunter »
what ones did you use rage?
ragedigital
4000+ Posts
4000+ Posts
My 400 came with custom bones, but they were roughly a 1/2"-9/16" longer than the stock 600 ones.
haunter
Post by haunter »
interesting.
I got 2 sets of bones from you with that 400 frame and they were both identical to the 600 bones
ragedigital
4000+ Posts
4000+ Posts
This frame I have now was used for racing. They had to lower it otherwise the larger Hyperco spring on the TC wouldn't fit through the swingarm. It lowered the bike a little...
