Headlight problems
Fizzinatorr
Level 6.5
Level 6.5
Headlight problems
Post by Fizzinatorr »
Headlights don't come on....no matter what i have tried, carefully checked, all fuses (also for continuity), all wires, all connections
symptoms, bike starts and runs, engine stop and start switch clearly working, left side: dimmer switch not working, no light indicator in gauges, turn signals work, horn is weak but there, brake light is fine
Have new bulbs so it's not that, i believe i'm down to just the left side switches, specifically the high/low dimmer switch
any ideas?
haunter
Re: Headlight problems
Post by haunter »
hmmmm
head fuse is ok huh.
sounds like a short somewhere drawing current from that part of the bike
Fizzinatorr
Level 6.5
Level 6.5
i was right, some undone wires inside the dimmer switch, this should fix it
haunter
Post by haunter »
should do it.
that would interupt power to lots of stuff up there!
Fizzinatorr
Level 6.5
Level 6.5
yepppppppp that was it. all fixed, there's not a huge difference between the xenon and stock bulbs...it's more blue but i can't really say it's a heck of a lot brighter
