odometer/speedometer on new (swapped) front ends?
- abs929cbrrr
- 1000+ Posts
what has everyone done for a speedometer/odometer when you swap a front end out of the fzr600? i know i cannot use my speedo cable anymore but is everything controlled thru that? i need to know how many miles i ride and if i get the bike inspected ill need somthing else.
what ya guy come up with? i need somthing simple and easy and not costing a ton.
I think we need a sticky someplace of what people have done since its more involved then just swapping forks and a wheel.
02 xr200r set up for XC
96 trx300ex set up for XC
im roadbike less!!!!!!
- abs929cbrrr
- 1000+ Posts
Re: odometer/speedometer on new (swapped) front ends?
ok i am going with a bicycle speedometer. i do not feel like spending $250 for a R6 digital gauge swap when i can do the same thing for $10-$20 thru walmart...i can buy alot of speedometers for $250! i am keeping the stock fzr gaguges i just need speed a distance traveled to keep track of oil changed.
Im using an ElectroSport digital speedo. It has a reed switch sensor and also has all the indicator lights and a tach as well as odometer and all that other good stuff. its a standalone and can replace all the guages and only cost me about $130 for the complete setup. I also got one with a fuel guage on it to set up with my YZF tank.
Abs,abs600fzrr wrote:what has everyone done for a speedometer/odometer when you swap a front end out of the fzr600? i know i cannot use my speedo cable anymore but is everything controlled thru that? l.
Why cannot use the speedo cable ? and yes you speed & distance come thru that.
I have ducati front end on a bike with suzuki wheels (the bike is a yamaha ) with third party guages and i use the speedo cable all I did was fit a peg in the fork end to stabilise the drive gear hub & pick up the drive in the wheel hub as normal
- abs929cbrrr
- 1000+ Posts
my 2006 zx6r front end does not have room or connections for a speedo cable. those bikes were all digital speed senors. i have no room to mount and use it either.
http://www.electrosport.com/street/speedometers.php
Im using the 2800 series for mine, but Im also using a seperate analog tach.
http://trailtech.net/vapor.html
I've seen a few of those on ebay as well. I thought about doing this on my fzr as well.
Hmm learn something new every day <BG>abs600fzrr wrote:my 2006 zx6r front end does not have room or connections for a speedo cable. those bikes were all digital speed senors. i have no room to mount and use it either.
- abs929cbrrr
- 1000+ Posts
i read alot of post on the archives people had problems hooking the trail tech things up. i am totaly fine with all my gauges. i could care less what they look like. i just need somthing to say how fast i am going and how many miles i have gone. thats all the speedo cables does on the fzr. i still have temp and tach. i will go look this weekend at some wireless one for mountain bikes.
Put on some R6 digital gauges.
I've got a wireless one for my pedal bike, works great and no wires to get caught and snap.
- abs929cbrrr
- 1000+ Posts
digital gauge swap will run me at least $250. R6 cluster are going for $150-200 alone.
- ShogunTX
- Level 4.5
My electrosport was $150 plus shipping
How difficult where they to install?ShogunTX wrote:My electrosport was $150 plus shipping
