Bad gasket? where does this hole go into anyway?
I just changd the pistons and its a new gasket in there between the head and the barrels and base all new stuff.
Thanks
Steve
Don is right that is the "blow the crap out" hole I would be looking at the rad hoses that run over that section and into the plastic air dam that is just to the rear of spark plug valley & funneling in water. this may be the source of your flywheel corrosion hassle if the water is getting into that space.China_Racer_1 wrote:Ah so I will look for a leak that is filling that trench up then its a constant leak so something has to be filling it.
Thanks a bunch
Yup every bike should have oneharo504 wrote:haha you heard them its the plugs butt hole hahahahaha to me its only funny if i laugh
