exhaust chop you tube sound
tony
100+ Posts
100+ Posts
Post by tony »
after the tail swap the exhaust looked to long so i purchased a cheap stock exhaust to chop , i cut the end off with grinder, i then cut 150mm off ,i was lucky as this was the end of the baffles ,i then ground the baffles down to the inner flange, also grond the internal baffle on the end cap, i then welded the end cap back on , now it has a nice rumble sounds great and not to loud
http://www.youtube.com/watch?v=ducSN_rj17M
gallery2.php?g2_itemId=18868&g2_imageViewsIndex=1
JRK5892
Level 1.5
Level 1.5
Re: exhaust chop you tube sound
Post by JRK5892 »
love that tail swap! one of the cleanest i have seen! nice work on the pipe! should high heat that sucker white to match the tins! (plastics)
http://www.thepowderpro.com
The Powder Pro
