aftermarket shock?
aftermarket shock?
Upgrades:
Re: aftermarket shock?
Yep....that's a Fox Twin Clicker if I'm not mistaken. Looks like it needs a rebuild though..
Yah but for $50... How much is it to rebuild do you think?sweekster wrote:Yep....that's a Fox Twin Clicker if I'm not mistaken. Looks like it needs a rebuild though..
Upgrades:
I doubt it will go for that. Maybe more. As far as rebuild I don't really know what it would cost to rebuild one since I've never actually had that done. ModKing knows how to rebuild them so he would be my first suggestion as far as getting more info.
Honestly, I'm not sure what that is. It might be a "Progressive" like he states, but I haven't seen one with the top like that.
It is certainly not a Fox shock... sorry.
I'm sure someone company would rebuild it. Most rebuilds, including Fox Shocks, start around $200. That does not include a new spring.
Check the WIKI to see the differences in the shocks.
darrin
darrin
- megaloxana
Well the buyer doesn't seem to know jack shit about parts he sells so I'm guessing he got progressive from reading a label on the shock somewhere.
So who's gonna be the one to buy it?
- abs929cbrrr
- 1000+ Posts
i thought about bidding but its not worth it to me. i know to know exactly what i am buying and it in not very good shape. i would rather spend $50 for a new 08 or 09 gsxr 1K shock or somthing.
02 xr200r set up for XC
96 trx300ex set up for XC
im roadbike less!!!!!!
yeah, that don't look right, plus the rust is not a good indicator. As bad as our suspensions are stock, it will be worth it to spend more money and get a better shock.
